How to get rid of an outdated TV
I entered a Samsung TV in A/V and now I can’t delete it. The TV is long gone, I tried deleting but it just keeps reappearing. I tried resetting to factory but,yes,it STILL keeps returning. First, I am not a fan of Vera 2 reset to factory (WAY too much does not get reset) but how do I delete the TV permanently.
Note, if it is relevant, I use I era for IOS as well as cp.mios.com
Vera 2, UI5, latest f/w (622?)
There is no reason to create another post that asks the same question in another post you created earlier.
http://forum.micasaverde.com/index.php?topic=15530.0
  • Garrett
My apologies, but I thought the former ones did not post. Turns out, I guess the moderator moved the post since I posted it in General and it appeared here in Getting Started & Initial Setup.
Noob mistake on my first posts in the forum
Can you please describe where this is showing and what is displayed. The reason I ask is if you are looking in Devices > AV Gear, it will add may display devices in Internet TV which are related to apps you use on your iPhone such as Automator or SQ Remote.
If it is a normal device and you go to the Advanced Tab is there a parent device represented?
Maybe a screen capture of what you are seeing.
It shows in two places: in Vera UI|Devices|AV gear and in Vera Mobile|TV/AV|Devices
And one other special place: in Greg it shows up in the memory of the Vera 2.
Do you utilise any mobile phone apps as they will appear in this area as will several types of other devices that are connect to a network.
They have no impact on performance and if you use an some mobile phones (SQ or Automator) if you delete them as soon as the app connects to your Vera, they will regenerate.
