Hello,
I was confident I could use OS.execute (‘top -n1’) from a luup script until I realized that OS.execute does not return the output of the command. How could I do this?
Sent from my GT-I9100 using Tapatalk 2
Hello,
Try io.popen() instead, although top may need special params unless it can only show one cycle of output.
You could try to pull the info from /proc.
I have tried that but I am not sure this is available.
Yes this is an option but it brings us back to io.popen
And I could check: this I’d not available By default but installable and works 8)
