I have a door sensor that i wish to use to run a event only when its dark outside.
I want the lights to go on when the door opens, but only if its dark outside, like after 21:00 or so.
It was easy to setup the normal scene that turns on the lights when the switch is triggerd but how do i set it up that it only runs after a specified time ?
