How to downgrade firmware
This is a simple question. How can I roll back to the last version of the firmware as this new one does not work and the old one did? If you could just tell me how to do it I would extreemly appreciative. Will I be able to keep my settings, devises and scenes?
Thanks,
Scot
New to this…
If you search for UI7 Firmware Custom URL good things may happen to you.
http://forum.micasaverde.com/index.php/topic,32278.15.html
I followed the advice on how to downgrade, did so, kept the settings, scenes etc. and now everything works great again. I suspect that the upgrades are overall a good thing but this latest one, (1320) seems like a giant step backwards. Not being able to heal or see the status of the installed devices and, the fact that all of motion detectors (Linear) were not working, made the decision to go back in time a good one.
I am right there with you. 1320 is a total disaster, my Vera Edge was running perfect prior to the update, sow it keeps crashing every 30 seconds. will revert back to the last known version.
Is there any way to prevent the UI from telling me about the new firmware on startup, I’d like to ignore the latest
Top of the page at the link below might have a solution for you:
http://forum.micasaverde.com/index.php/topic,38389.120/topicseen.html
alansmithee fixed the issue by modifying the get_version.sh in /www/cgi-bin/cmh/
