Hello,
I installed a Fibaro Door / Window Sensor.
My first installation does not include a temperature sensor.
The detector worked well.
I have now connected a sensor DS18B20.
Previously I had removed from my VeraEdge configuring the detector.
I subsequently included again Fibaro Door / Windows sensor. I did not see an icon appear with the temperature measured by the probe.
How to get there?
Thank you!
The specification of my DS18B20 is:
Output lead: Red(VCC), Yellow(DATA), Black(GND)
Power supply range: 3.0V to 5.5V
Operating temperature range: -55?C to +125?C (-67?F to +257?F)
Storage temperature range: -55?C to to 125?C (-67?F to +257?F)
Accuracy over the range of -10?C to +85?C: ?0.5?C.
Michel
Try not to double post …
See you other thread
There is so much information and I would say an overdose of informaiton. This type of situation leads me to understand an avenue (process) to connect a single sensor DS18B20 and get reading sensor value.
Fibaro products are quality. The solution of using a “Fibaro Door / Windows FGK - 101” with a DS18B20 Temperature Sensor is a very good solution for live temperature of my pool.
After reading the documentation for a few hours and the blog, have tried all possible avenues, I am looking for a solution.
