I created a scene that switches a light on at the same time of day for every day of the week. After the light is switched on it counts down 4 hours before switching off. Thought I’d just share how I did it.
- go to Automation>scene>new scene
- name your scene i.e, light timer
- click on a device(s) “ON” button that you want to be switched on
- click schedule
- click add schedule
- name your schedule i.e., “light timer”
- click day of the week based radio button
- click radio buttons for the day(s) of the week you want the devices to come on
- select the time of the day you want the devices to come on
- click done
- click confirm changes
- click save
- click automation
- click the wrench on your new scene that you named in step 6 above
- click immediate and click manage delays
- enter the time require for count down, then select seconds, mins, or hours as required.
- click done/close
- click the “OFF” buttons on the devices you switched on in step 3 above
- click save
Your done. Now when the day and time becomes true the devices will switch on. After the countdown you defined they will switch off.
