I am a first time Veralite user.
I have only one device currently, a kwikset lock (910).
After spending an hour, I can currently pair the lock with Veralite and all the pin code I programmed are working fine.
My question is, how can I limited some pin codes access time?
For example, I want one door pin code can only be used ever other Monday between 9am-4pm. make it invalid outside this timeframe.
How should I do that?
My veralite is using UI5 I think with UI6 in beta.
Click the wrench on the device icon, then go to the Pin codes tab. Find the code that you want to govern, then click the Restrict code drop down box. From here you can limit it by month or by day of the week. For instance, you can have it only work on Mondays between 0900 and 1600. I don’t see a way to limit it to every other week though. I’ll play around with it tonight and try to get back to you.
I like you couldnt figure out the restrictions at first but then i found the menu and set a restriction that still didn’t work. what ended up fixing it was I deleted the device then re added it and now it works with restrictions
