‘output_format’ is not recognized as an internal or external command,
operable program or batch file.
‘DeviceNum’ is not recognized as an internal or external command,
‘serviceId’ is not recognized as an internal or external command,
‘action’ is not recognized as an internal or external command,
‘newTargetValue’ is not recognized as an internal or external command,
It also then creates a file called data_request@id=lu_action in the folder where my .cmd file is, I don’t want these files whatever they are?
What would be the correct syntax to put in to the .cmd file ??
error on line 2 at column 28: xmlns:u: ‘Unknown Service’ is not a valid URI
Below is a rendering of the page up to the first error.[/b]
If I then put these URLs in to a Lounge-On.cmd and a Lounge-Off.cmd file and double click them the scene is run OK and the lights go on and off. So guess I don’t need to worry about this ‘Unknown Service’ is not a valid URI error ?
If your wondering why I want to create these .cmd files, once I have them created, I will be able to run them on the Windows Media Center PC, initiating them from either my Logitech Harmony universal remote control with custom buttons on the LCD screen, or by using my Amulet Voice activated MCE remote control. So I can speak “Lounge-on” in to the Amulet remote and then it runs one of the .cmd files and the lights come on!
I’ve finished creating all my .cmd files on the Windows 7 HTPC for initiating various scenes and controlling devices in VeraLite. They work well with my Logitech Harmony universal remote control. ;D
Thank you so much for sharing this (it’s well timed as) my friend’s built a php5 script that looks at all his unread emails for a particular piece of information (such as a sender/subject/keyword) and once found, it would run a scene particular - He was having trouble getting it to work/run on the command lie so I’lll let him know your findings, if he’s not fixed it already.
