Hello, I have this situation I was hoping someone would be able to help me with
I have a pool with a pool heater
a) I have bought an intermatic CA3750 (http://www.amazon.com/Intermatic-CA3750-Multi-Volt-120-277VAC-Contactor/dp/B000YUCES2/ref=sr_1_1?s=hi&ie=UTF8&qid=1370238637&sr=1-1&keywords=intermatic+3750) to hook up this pool heater.
I would like to have an outdoor, wall mounted switch to remotely turn this on and off, thus as I see it, this switch would not require to carry a load as all it would do would be record on/off and relay that signal to the intermatic 3750 to turn on.
Can I use this very cheap switch (http://www.amazon.com/Leviton-VP0SR-10Z-Digital-Coordinating-applications/dp/B001HT4M70/ref=sr_1_1?s=hi&ie=UTF8&qid=1370238761&sr=1-1&keywords=z-wave+switch), usually used in 3 way situations for this control.
I actually do not need this switch to do anything but record on/off for my vera lite to turn on the ca3750.
if this switch will not work, any others you might suggest.
Thank you!
Collin
