I’m not a Vera expert and have run into problems with one of my Veralites. Having read a lot of posts I am now very suspicious it is a memory utilisation issue. I would like to check memory utilisation and I read this in an old thread …
"Going in via SSH and running the free mem command will give you an idea of what you’ve got free. "
but I have no idea how to do this. Can somebody explain the process in more detail or point me in the right direction please.
Thank you everyone. I finally retrieved the data through installing system monitor. I figure from that if the veralite has 64 MB of RAM then memory capacity is not an issue as it shows 28310 Kb free memory. Back to waiting for a response from support
