I added three wall plate controllers to my Zwave network and while all three controller’s IDs are below 32, they can’t control any devices whose Node ID exceeds 32.
I tried to change Node ID in the advanced settings but after saving new values Vera offered to assign device to a room with the old Node ID. I have a lot of gaps in the Node ID lineup and reusing unused numbers would solve the problem.
If you just added the controllers and their ID’s are <32, that would imply:
A) You don’t have any nodes >32
or
B) You’ve reached node #232 and are already recycling the ID’s you indicated as gaps in your lineup.
Did you mean that you can’t control devices whose Device # is >32?
or
