How to associate AD142 lamp module to EZMotion detector 3 in 1
Hello,
i have to associate my AD142 lamp module with Motion sensor that there is in EZMotion 3 in 1 sensor.
What i want to do: i want to set the Motion Timeout (called On Time variable in EZMotion device) equal to 1 min. (it is the lowest value) because i want to SWITCH OFF the lamp after 1 minutes from the last motion detection.
To do that i think i have to associate AD142 to EZMotion Sensor.
Some one can help me?
Please do not double post. You already have another thread open which you have just asked this same question. There is no reason to create a duplicate topic. It will not get your answer any faster.
  • Garrett
@tureface,
Note sure if you are still looking for an answer.
The EZ Motion sensor sends its commands to association group 1.
So all you need to do is in it’s device settings tab add group 1 association and assign this to the AD142 socket.
This guide will walk you through it - http://www.vesternet.com/resources/application-notes/apnt-16. It uses an Everspring sensor, but the principles are the same, just use group 1 rather than group 2.
Mark.
