Hi all,
for better understanding here is my house plan with the z-wave devices location. the total distance from end to end are no more then 15meters.
i want to able to use TZ66D from Room1, to do association to turn on and off the “Fibaro switch 1 and 2”, “Everspring On/Off 1”, and “Homepro On/off”, with total of 4 association.
so my problem now is i only able to turn on and off “Fibaro switch 1” and “Eversping On/Off 1” only.
i tried to move those not functioning devices nearer, and it works fine. so this is definitely the signaling issue. believe to due to the concrete wall.
so now i have several questions:
i) each devices have its own z-wave route recorded themself? example, TZ66D will know the route to “Fibaro switch 1”, then “everspring On/Off 1” then only reach “Fibaro Switch 2” and “Homepro On/Off” without the Vera required?
ii) if above yes, is this automatic or manually? how to do if manual?
iii) i saw in Mios, that there is Manual Z-Wave route (advanced) under device options. not sure this is the one? i click on the help but nothing shows, any one have idea how to set this
iv) any possible solution to solve the problem i have???
please, i am total dilemma on this already. thanks
