How to Alert on Log entry "CPU overloaded"
When the Very Secure crashed, according to the support team, they saw “CPU overloaded” events in the log. [size=10pt][size=8pt][ReportError nm_cpu / CPU overloaded, count: 5, sec: 1206, idle: 3, system: 40, delay: 184 / <0?771df000>] [/size][/size]I’m wondering if there is a way to alert when something similar appears in the log and maybe even trigger a reboot?
Thank you
Not directly related to the log entry, but several plugins (EventWatcher, SystemMonitor?) expose a CPU-load type of parameter.
In particular, EventWatcher has a CPU05 variable giving CPU loading over a 5-minute average.
If really necessary, you could pull this directly from the pseudo-file in [tt]/proc/loadavg[/tt], without even needing a plugin installed.
Edit: I should add that I routinely log memory usage (free and available) plus CPU load for all three of my Vera systems. See attachment
[quote=“akbooer, post:2, topic:198938”]Not directly related to the log entry, but several plugins (EventWatcher, SystemMonitor?) expose a CPU-load type of parameter.
Edit: I should add that I routinely log memory usage (free and available) plus CPU load for all three of my Vera systems. See attachment[/quote]
Yeah - but none of the ones mentioned alert on problems - just log them. To me it makes sense that there should be some alert when an event occurs in the log that is indicating instability or a possible crash. . . .
