So with the Vera hub, and polling and battery operated sensors, the vendor indicated that polling should be reduced to keep the battery usage down to a minimum. As such I want to turn off polling for a device (it senses temperature or it senses open/close of a door).
Where does one change the polling interval for a device?
(I’m thinking about using some of the Sensative brand strips to detect garage door being open, or water detection under the water heater or washer).
