how many controllers I can add one zwave device ?
hello !
I’m using intermatic HA07 and ge45601 , ha07 is a primary and ge45601 secondary…
I tried add the device to vera3 and was not possible…
I read in some place ate 5 controllers I can have…
some my devices is in difficulty acess…and is not so good to press the buttom to remove of his actual network I would like to come with that all to vera3…
some suggestion ?
thanks !
IIUC, you have the HA07 as a primary controller with the GE as a secondary to it, on their own Home ID, and trying to add them as secondary controllers to Vera?
If that’s the case, you would need to reset the HA07 and the GE before Vera could include them.
Also, IF you’re currently running Vera 3 as secondary, and are currently able to include devices through the GE, and are looking to do the same with Vera 3, you’d have to run Z-Wave firmware 2.78 on Vera.
(In terms of number of controllers, I didn’t think that was limited, but there are limits as to how many controllers, or devices, a device that supports associations can be associated with (to work reliably), as memory is limited. For example: a Leviton device can only be associated with up to 5 scene/zone controllers (reliably).)
