How do you demote an existing Vera 3 to be secondary controller
Does anyone know how to demote a vera3 to be a secondary controller?
I’m adding a Honeywell tuxedo alarm controller that has a built in zwave controller, I want to experiment with it being the primary zwave controller.
I see how to do a “controller shift” on prior Vera models, but cant find anything on the Vera 3.
Thanks,
Ken
Its in the setup tab then Z-Wave Settings and then the advanced button.
As to getting it to work is another problem:)
[quote=“strangely, post:2, topic:173457”]Its in the setup tab then Z-Wave Settings and then the advanced button.
As to getting it to work is another problem:)[/quote]
LOL… Ney too easy! - It would be nice if “Shift Controller” could do just that!! (send Primary info to active Secondary and Swap roles)
UPDATE: Shifting role is done in LOW POWER mode only - So bring both controllers in close proximity for it to work!!!
I finally got that to work ;D
