How do I upgrade z-wave firmware from 2.78 to the latest version in UI7?
Updated my Vera 3 over the weekend and it did not upgrade the firmware version on the z-wave chip. How do I upgrade that piece? Am having range issues and assume that heal is not running because it is the old chip.
Vera 3’s do not support Z-wave Plus, so I don’t know if the firmware is actually applicability to the Vera 3, I believe it was only for Edge.
Wish I could use my aeonstick in the USB port. Much easier to carry around to include devices with.
I stopped carrying around the vera along time ago. Could be the size of my network but I rarely if ever have to move my vera to include a device using full power inclusions.
I am also curious about upgrading my z-wave chip firmware. I had an issue with 2 Z-wave devices dropping out every night after I upgraded my VeraLite to firmware 1.7.760. I reported it to Customer Support and received the following response.
I would like to let you know that I managed to set the Z-Wave settings on your unit as they should be, and also upgraded the firmware on the Z-Wave chip. Please test your devices and controller and let me know how it goes.
It appears you can upgrade the Z-wave chip. I am sure you don’t get the latest standard but, it seems it might help stability. I haven’t had the dropout issue since this occurred. I would like to know how to check my version and how to upgrade it if a newer version is available.
