I am assuming there’s an easy way to set this up, but not sure where…
Most of us use the VirtualSwitch plugin to create a switch called Away. We can then test the state of that switch with Luup or PLEG as we prefer. The state of our Away switch can also be set by the arming/disarming of security alarms or pingability of Smartphones etc.
I do not know if VirtualSwitch will work on UI6 yet.
I’ll look into this, thanks.
I wonder if there’s a hardware device that can used to set this… but from a smartphone would be an alright solution.
I personally use the VariableContainer plugin and keep a count of occupants. That way the home only goes into “away” mode when the last person locks the door. Otherwise pretty much the same idea as checking the status of a virtual switch.
As far as detecting occupancy, there are plenty of threads on the topic in these forums. Some ping their phones. Some use the iPhone locator app. Some check for presence of keys or other dongles. I personally use the iPhone locator to correct the occupants count (in case more than one person left at the same time–the number of times the door gets locked won’t be an accurate indicator of how many people are home).
Where does one find the VirtualSwitch plugin? It doesn’t appear in the App search on my Vera3 with the latest firmware.
Nevermind: Found it at MiOS Apps
Cheers!
If by latest firmware you mean 1.6.xxx, you may not be able to install many of the plugins until the developers have had chance to update them.
I wonder if there's a hardware device that can used to set this...
You could use any light switch.
Yep… or couldn’t I use the Aeon mini fob? It has 4 buttons… so I could set one to be: Away/Armed, one for Home/Armed, one for Home/Unarmed. Of course, opening the door with a keycode also can set it to Home/Unarmed.
If we leave the fob in the kitchen, whoever leaves can simply hit the Away/Armed button on their way out and that solves all of the complexity of trying to figure out if someone is home or not.
