I installed a wd00z to use as a 3 way switch but when I tried to associate it with a wd500 it failed to configure… deleted the device from zwave but now the status light o the switch remain off and I can add it back to vera. All connections are confirmed good.
I think you have some typos in your post. It says I can add it back to vera, but i think you meant to say that you can not add it to Vera. I would recommend:
- Power cycle the switch at the breaker.
- Exclude the switch(again). (Note that this switch has two include modes NWI is a single tap, standard include is a double tap. Use double tap when excluding.)
2a. While not usually necessary, you may wish to power cycle the breaker again. - Include the switch.
To reset a WT00Z-1 to factory defaults, you have to Exclude it.
Power cycle my breaker and but the indicator light on the switch remains off.
Have you successfully excluded and included it?
The switch doesn’t seem to respond to anything.
Then it sounds like the switch is dead.
