how do i find out what slot my keypads are on (related to broadcast labels)?
this is probably more a DSC question than a MCV question, but i wanted to post it here because it’s related to the plugin (and to get the maximum amount of help i can get).
i have a dsc 1864 with the wireless transceiver and two keypads…a PK5500 and a WT5500. all other zones are wireless (11 total thus far). everything is working, including central station monitoring (via alarm relay). i can arm/disarm via both the eyez-on interface as well as through vera.
the one thing that isn’t working is broadcasting the labels to my vera lite…and i now realize i have no clue what slot my keypads / Envisa|ink are on. is there an easy way i can figure it out, without resetting everything? i’ve tried searching but haven’t had any luck, probably because i can’t figure out what to search for to best figure this out…
also of note: broadcast labels did work from PK5500 to WT5500, but a subsequent label broadcast from the PK did not make the labels show up on the vera…
Envisalink modules don’t support label broadcast, so the plugin cannot pickup labels when used with those devices.
they don’t?
http://code.mios.com/trac/mios_dscalarmpanel
If its preferred that the plugin uses the default mechanism of using the labels from the Alarm System, there are usually several ways to rectify the above behavior without changing the above variable:
If labels have previously been programmed in a keypad, then attempt a label broadcast from the keypad they were originally programmed from by entering *8[Installer code]998
If labels were never programmed then they can be programmed them from an alpha numeric keypad and a subsequent label broadcast
Program the labels to the panel using DSC DLS software
The current generation of Envisalink modules don’t have enough memory/storage to “hold” the Labels for when the Automation entity (Vera, in this case) makes the call to retrieve the Labels.
I wrote that code some time back, when @strangely loaned me a IT100 board. It works with an IT100, but then I moved to a 2DS module and it stopped, so we enquired with Envisalink as to why Label Broadcasts weren’t working…
Here’s the text just before what you’re quoting…
... or were programmed before the IT100 was installed,...
The code still makes the call to retrieve the Labels, it’s just that it’s a NOOP on the 2DS/3DS boards.
ahh, gotcha. so, i can edit the labels myself though by changing the advanced variable…right?
also, i’d still like to be able to know what slot i have everything on…is there a way to figure it out?
That option is really just for the benefit of [some] IT100 users. With an Envisalink board, the Label broadcast “request” is made, but no responses are given back from that board, so the Labels will never be over-ridden.
also, i'd still like to be able to know what slot i have everything on...is there a way to figure it out?
I'll leave that to some of the others here. My system is just a test-system, so I've never had to do that.
You may also want to search over on the DIY Alarm Forum, since they have a lot more answers than we do :wink:
