How do I disable this plugin via PLEG
I want to disable the plugin deus ex machine in a “logic action”. There is an option in the logic action to enable it , but not to disable it.
is this a bug , or am I overseeing this?
How would I disable this plugin in a logic action?
attached a screenshot of the logic action where only the option “enable” is.
edit : I just see now there is also a “non- advanced”- option , there you can toggle between enable and disable!
edit2 : no , something is not right , when I save and come back , the plugin is suddenly twice in the “logic action” list.
edit3 : Just tried it with the “non-advanced” option in the “logic action” but the plugin does not change status.
Anyone has a solution?
Thanks,
Cor
Is this a bug? , how do other people do this , disabling the plugin when they are at home , automaticaly I mean. I really would like to disable this plugin via PLEG .
Cor
Use a virtual switch or multiswitch to indicate your home/away status and use it in the logic of whether the plugin runs or not. I’m not familiar with that plugin so if this doesn’t help, I apologize in advance…
