How do I configure the parameters on the controllers.
I’ve bought one Fibaro Roller Shutter module and I want to change the parameter 14 from 0 (monostable switch) to 1 (bi-stable switch).
Where can I do this within the MCV? Please explain step by step since I’m a rookie in MCV.
Thanks in Advance,
Johnytalker
Quinten
February 25, 2012, 11:00am
2
If you’ve added the device already, go to the Settings and then to the Device Options tab. Have a look at the attached dialog from my Fibaro dimmer module (which uses the same parameter)
Ap15e
February 25, 2012, 11:16am
3
Thanks Everybody,
I managed to solve to problem.
Now I’m having another problem with a 2nd type of roller shutter that I have, from Aeon Labs.
The problem is that Very is having trouble in adding it. First few times it didn’t appear and now appears has an light dimmer module.
Is it possible to force the type of controller or should I insist in pairing the normal way? Or is there any other and easy solution?
Thanks in advance,
Johnytalker
