Some progress last night. I tried using Luup from Apps → Develop Apps → Test Luup code (Lua), and entered a series of commands to turn the LED on and off, and it worked pretty much right away, as far as I can tell. Took 10 or 15 seconds to get from my computer to my bedroom to check, so I can’t say if it was instantaneous or not, but it was good enough for the purposes I needed.
To turn the LEDs off:
luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='48',Data='112 4 3 1 2'},1)
luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='49',Data='112 4 3 1 2'},1)
luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='50',Data='112 4 3 1 2'},1)
luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='56',Data='112 4 3 1 2'},1)
To Turn the LEDs back on:
luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='48',Data='112 4 3 1 0'},1)
luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='49',Data='112 4 3 1 0'},1)
luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='50',Data='112 4 3 1 0'},1)
luup.call_action('urn:micasaverde-com:serviceId:ZWaveNetwork1','SendData',{Node='56',Data='112 4 3 1 0'},1)
I used a PLEG schedule to activate this code, and it didn’t seem to work. Any idea why it wouldn’t work from PLEG, but would work from Apps?
Action: cStatusLEDOn
LUA:
luup.call_action(‘urn:micasaverde-com:serviceId:ZWaveNetwork1’,‘SendData’,{Node=‘48’,Data=‘112 4 3 1 0’},1)
luup.call_action(‘urn:micasaverde-com:serviceId:ZWaveNetwork1’,‘SendData’,{Node=‘49’,Data=‘112 4 3 1 0’},1)
luup.call_action(‘urn:micasaverde-com:serviceId:ZWaveNetwork1’,‘SendData’,{Node=‘50’,Data=‘112 4 3 1 0’},1)
luup.call_action(‘urn:micasaverde-com:serviceId:ZWaveNetwork1’,‘SendData’,{Node=‘56’,Data=‘112 4 3 1 0’},1)
Action: cStatusLEDOff
LUA:
luup.call_action(‘urn:micasaverde-com:serviceId:ZWaveNetwork1’,‘SendData’,{Node=‘48’,Data=‘112 4 3 1 2’},1)
luup.call_action(‘urn:micasaverde-com:serviceId:ZWaveNetwork1’,‘SendData’,{Node=‘49’,Data=‘112 4 3 1 2’},1)
luup.call_action(‘urn:micasaverde-com:serviceId:ZWaveNetwork1’,‘SendData’,{Node=‘50’,Data=‘112 4 3 1 2’},1)
luup.call_action(‘urn:micasaverde-com:serviceId:ZWaveNetwork1’,‘SendData’,{Node=‘56’,Data=‘112 4 3 1 2’},1)
I’ve attached my latest status report. Any help would be greatly appreciated.
