I suspect that I am not seeing this option in the UI5 Settings screen for my Yale lock, and other people are.
When I click on the settings wrench for my lock, I have the following tabs: Control, Pin Codes, Settings, Advanced, Device Options, Logs, and Notifications.
Where should I see the option to set autolock delay? Do I need to add a configuration setting under Device Options?
[quote=“kxb, post:3, topic:175870”]Thank you so much for posting that!!! I’m not crazy. Mine doesn’t have those options.
I’ll try removing it, and adding it back again, and see where I get to…[/quote]
Hopefully that fixes it for you. I am unsure if different Yale models have different options. I have Yale YRD210-ZW-ORB Real Living Electronic Push Button Deadbolt
I have found that using the PLEG plugin to handle the auto re-lock more useful. If you are having a social event you can disable it quickly on your phone and re enable it once everyone leaves. You also have more control over the time of the auto re-lock.
