I don’t have a Vera system! I have a Simon XTi with FrontPoint Security and got the evolve switches as I hear good things. I have them installed correctly and they both show up with the LTM-5 as a z-wave device and the LRM-AS as a z-wave dimmer but don’t know how to associate the LTM-5 to the LRM-AS with the GE simon XTi system. There is no way that I’ve found to make a scene or associate them in the www.myfrontpoint.com site. Anyone know how to link them without a VERA system?
Thanks,
Rob
Why did you open a new thread when you already have asked the same question in your other thread that you own:
http://forum.micasaverde.com/index.php/topic,17258.msg133889.html#msg133889
Please do not cross post.
Sorry! I wasn’t trying to cross post. The original thread was about wiring and I mention the syncing once the wiring was complete. The repsonses that I recieved were specific to Vera even after I had mentioned I don’t have a Vera system, so I thought I’d start a new thread with a topic that was clear and concise and relates to the new issue. I guess I should’ve started this thread new from the get go instead of changing topic on the last. Sorry for the inconvenience.
Rob
P.S. do you have any idea how to link the 2 switches without using a vera system?
@fulmitz - You will need a Z-Wave controller of some kind, such as Vera, to perform the association. The instructions on how-to will be different for each controller.
I have zero knowledge of GE Simon XTi, so I can’t help you there. I would recommend you contact the company’s support department. You can also try the DIY Alarm Forum if you prefer.
Z-waver,
Thanks for the update. Your wiring was spot on. I just spoke with frontpoint security and they said the simon xt is the only controller and won’t let another device control a light. I’m wondering if I bought a Vera, would it sync the 2 switches, then I turn the Vera off would the link between the 2 switches still exist as long as the Z-wave network was still running with the simon xt? Oh yeah, it’s an XT, not an XTi.
Thanks,
Rob
Yes, associations are local to the device. Once the LTM-5 is configured with the association it no longer needs the controller and acts directly on the LRM-AS, provided that there is a Z-Wave path(direct or routed) between the two.
Now I have to decide if it’s worth $180 to connect two $45 switches
Can you get alarm monitoring service with the Vera or is it self monitored?
WOW!!! Just got an update from Alarm.com via email. They told me exactly how to do it. I only need an Aeon Labs Minimote which I found for $44 with free shipping. They also included detailed instructions how to set it up, looks similar to setting up with Vera. Then they say to remove the minimote from the network and the connection stays. I’ll cut and paste the instructions to hopefully help others!
Thank you for contacting Alarm.com
You can find a list of empower devices that we support through this link http://alarm.com/empowerdevices.
In regards to your question, It seems like you are setting up the Evolve 3-Way Switches. I have detailed instructions in this email.
It is important to note that Evolve 3-Way switches must be set up through wireless associations and that they will not work if they are installed using a traveler wire like a traditional 3-way switch. Also, the installer needs to have a master switch (has a blue load wire) and an accessory/slave switch (does not have a blue wire). They will also want to have a controller that can handle associations such as the Aeon Labs Minimote.
Instructions for creating an Evolve 3-way switch:
? Enroll Evolve devices onto the Z-Wave network.
? Enroll the Aeon Labs Minimote
o Press the ?Learn? button on the Minimote and the blue LED will blink slowly
o Put the panel into learn mode.
o The blue and red LEDs will blink quickly on the Minimote. The blue Led will stay solid for 2 seconds to indicate success
? Press ?Associate? on the Minimote and wait until the LED turns blue and blinks slowly
? Double Tap the paddle on the dimmer/switch (Master) and the Minimote LED will start blinking quickly
? Double tap the paddle on the accessory switch (LTM ? 5) and the Minimote LED will become solid for 2 seconds
? Delete the Minimote from the Z-Wave network
? Reset the Minimote before using on another network
Please let me know if you have any questions or concerns.
Sincerely,
Alarm.com CORE
I’m ordering today and will update once I see if it works or doesn’t
-Rob
