How do I add a relay module behind a UK mains power socket. Which module should I use and what wiring diagram should I follow? Many thanks.
You’ve asked this question in several different posts. By posting a new topic asking the same question will not help you receive a faster response. Many on this forum will overlook your post.
- Garrett
Many apologies. I put it here in the end as I thought this was the correct place. Please delete it if that’s better for the forum organisation.
