How disable the "device not responding" with a camera switch off
Hello,
I have 6 cameras directly added in the camera part of ma veraedge and also the vera edge control the wallplug of all camera to switch on/off
When the camera is switch off, i get an alert “device not responding” in the message of the vera edge
How can i disable this control / verification to clean this alert message ?
Thank you
[quote=“redbullux, post:1, topic:185737”]Hello,
Thank you[/quote]
Turn the Wall plug on? If the device is setup, but stops responding your gonna get that message. You only get that in the setup UI tho. When your using a good app you will not see that.
Why are you unplugging all your cameras?
For all cameras in my house i house a plug EVERSPRING AN157-2 to permit ON/OFF action on all cams. In mode “AWAY” , all cameras is ON , No alert but when i come back and put “HOME” mode on the Vera Edge, i get the message “Can’t Detect Device” on all cameras because the Plug EVERSPRING AN157-2 is OFF. How can i disable this detection alert ?
You have already posted this, and we didn’t have a solution for you yet.
