How Can Stop Scenes from activating when another is active
I have a few scenes that control my heating. However I would like an override capability so that I can keep heating on permanently and not be effected by those scenes. How can I have a scene (or something else) that switches the heating on and ignores other scenes related to it?
Many thanks
Maybe use a virtual switch plugin to be the override and have the other scenes check for the virtual switch state when they run to disable if need be? You can change the state of the virtual switch by a scene or manually.
I hadn’t thought of that. Thanks.
