I have clicked in Controler Shift Buttom…and now I can’t add a devices because says: Not a primary controller…
how can I change this to make vera3 primary controller again ???
thanks !!!
thanks !!!
This conversation thread solves this.
I’m using vera3.
NOTE: This migration only works with a Vera 2.
all I want is turn vera3 in primary again !!! the factory reset don’t runs…
I find this:
Version 3.20 L:1
House/Node House: 161b33b Node 1 Suc 0
Role Slave SIS:NO PRI:NO
Last update N/A
Last Z-Wave network backup N/A
but I can’t change !
do you have another tip ?
Did running ‘the hack’ not work?
I don’t know make “hack”…
I’m going in zwave settings/ advanced…there is:
Hack to convert 2.78 to 3.20 IMPORTANT: Read this first
when I click in GO…it says: command sent…
and nothing happens…
After a reload, or power cycle, does it still say [tt]PRI:NO[/tt]?
problem solved.
but I had restore one backup…
and now is running ok !!!
thank you for all !
