cPowderRoomFanOn and (((cPowderRoomFanOn; Now > 30:00) and !cPowerRoomFanDblClickOn) or (cPowerRoomFanDblClickOn and
(cPowerRoomFanDblClickOn; Now > 60:00)))
There are other ways to do this with self triggered schedules … but this is OK.
It’s common practice to post with key as it only works with (tied to) your VERA serial. No Vera serials are the same so it won’t help anyone but the owner of that VERA… Your good to go.
There are other ways to do this with self triggered schedules … but this is OK.[/quote]
I’ve tried to do it with the timers but I can’t seem to understand it. Can you provide an example?
To replace the NOW with timers, you need to create a schedule and start it via one condition, and then check its status in another.
So create a timer sPowderRoomFanOn as a Self Retrigger with 30 minute interval. Then as the action for cPowerRoomFanOn, start the timer via Advanced, Choose PLEG Stuff Control in the drop-down, and then start timer. You could do the same with a sPowerRoomFanDblClickOn Self Re-Trigger with a 1 hour interval, starting the timer as an action of cPowerRoomFanDblClick.
Then your cPowderRoomFanAutoOff would be:
cPowderRoomFanOn and ((!sPowderRoomFanOn and !cPowerRoomFanDblClickOn) or (cPowerRoomFanDblClickOn and
!sPowerRoomFanDblClickOn))
In some of mine, I have had to check to make sure the timer actually started though, cause I would find I turned something off right after I turned it on…
cPowderRoomFanOn and ((!sPowderRoomFanOn and (cPowderRoomFanOn; sPowderRoomFanOn) and !cPowerRoomFanDblClickOn) or (cPowerRoomFanDblClickOn and
!sPowerRoomFanDblClickOn and (cPowerRoomFanDblClickOn; sPowerRoomFanDblClickOn)))
