How can I copy the settings/network from my vera 2 to a z-stick?
I would want it to be secondary.
@ghurty
Here is some info for you:
http://wiki.micasaverde.com/index.php/Clone_Dongle
http://wiki.micasaverde.com/index.php/Vera2_with_zwave_usbdongle
Good luck,
  • Henk
[quote=“ghurty, post:1, topic:168974”]How can I copy the settings/network from my vera 2 to a z-stick?
Thanks[/quote]
I would want it to be secondary.[/quote]
Is this with 1 or 2 Vera’s; or something else?
I want to experiment with some of the features on homeseer. So far I like vera much better for the ease of use, but I love to experiment.
I tried what was suggested and it looked like it worked, but homeseer claims there is nothing stored on the z-stick
OK; so a Vera and an HS with a Z-Stick? If so, and assuming HS supports being a secondary controller, I’d guess you should be able to include the HS as a node into Vera’s network (i.e. Vera is primary). The network information then transfers over and the HS becomes secondary.
