Hello,
I have the Horstmann thermostat that is z-wave compatible. It works fine as a stand-alone set but i’m wanting to add it to my vera now.
It seems that the relaybox (controlling the heater) is a z-wave device which should react on the thermostat mode.
But the thermostat it self is a controller. While playing around with the setup keys next to the Add mode (which is to pair the relaybox with the thermostat) I found a SUB mode as well as a NET mode.
I have tried adding the thermostat as a controller to vera and when i select the NET mode there is a reaction at least.
Would anyone from Vera be able to decode this or help me out in getting the devices on my network ?
Here’s the log output forn LuaUpnp.log while performing the adding of the 2nd controller:
50 03/20/10 18:29:34.835 luup_log:0: L_sPhoneUI running version: 1.0.988 <0x402>
02 03/20/10 18:29:34.964 JobHandler_LuaUPnP::StartUPnPServices starting with /etc/cmh-ludl/ / http://192.168.5.17:49451/luaupnp.xml <0x400>
09 03/20/10 18:29:35.011 JobHandler_LuaUPnP::Run device 1 ZWave room 0 type urn:schemas-micasaverde-com:device:ZWaveNetwork:1 id parent 0 <0x400>
09 03/20/10 18:29:35.012 JobHandler_LuaUPnP::Run device 2 Scene Controller room 0 type urn:schemas-micasaverde-com:device:SceneController:1 id 1 parent 1 <0x400>
09 03/20/10 18:29:35.013 JobHandler_LuaUPnP::Run device 8 Generic IP Camera room 2 type urn:schemas-upnp-org:device:DigitalSecurityCamera:1 id parent 0 <0x400>
03 03/20/10 18:29:35.014 JobHandler_LuaUPnP::Run ready 3 devices installation 7203 missing pMem 0x73d000/7589888 diff: 544768 <0x400>
02 03/20/10 18:29:35.059 ZWaveNode::UpdateCommandClasses node 1 empty – – <0xc04>
01 03/20/10 18:29:35.061 ZWaveNode::SetInitialValues node 1 device 2 template was urn:schemas-micasaverde-com:device:SceneController:1 now urn:schemas-micasaverde-com:device:SceneController:1 UpdateCommandClasses failed: <0xc04>
09 03/20/10 18:29:35.062 ZWaveJobHandler::UpdateNodes dongle is node 1 device 2 iExtraNodesForTest 0 <0xc04>
04 03/20/10 18:29:35.065 <0xc04>
06 03/20/10 18:29:37.017 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 5 now: 1 #hooks: 0 upnp: 1 v:0x6ca860/NONE duplicate:0 <0x402>
06 03/20/10 18:29:37.020 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: Configuring ZWave devices now: OK #hooks: 0 upnp: 1 v:0x6ed4d0/NONE duplicate:0 <0x402>
09 03/20/10 18:29:38.008 ZWaveJobHandler::CheckReportChildDevices need to backup <0x402>
08 03/20/10 18:30:50.275 JobHandler_LuaUPnP::HandleActionRequest device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 action: AddNodes <0x2c0c>
08 03/20/10 18:30:50.276 JobHandler_LuaUPnP::HandleActionRequest argument InclusionMode=LowPower <0x2c0c>
08 03/20/10 18:30:50.277 JobHandler_LuaUPnP::HandleActionRequest argument NodeType=Controller <0x2c0c>
08 03/20/10 18:30:50.277 JobHandler_LuaUPnP::HandleActionRequest argument Timeout=30 <0x2c0c>
08 03/20/10 18:30:50.278 JobHandler_LuaUPnP::HandleActionRequest argument Multiple=0 <0x2c0c>
08 03/20/10 18:30:50.279 JobHandler_LuaUPnP::HandleActionRequest argument ControllerShift=0 <0x2c0c>
02 03/20/10 18:30:58.421 ZWJob_AddRemoveNodes::ReceivedFrame job#2 :addn (0x0x6bc348) P:10 S:5 Failed to go into learn mode retrying 1 <0x402>
04 03/20/10 18:30:58.425 <0xc04>
06 03/20/10 18:30:59.022 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 1 now: 3 #hooks: 0 upnp: 1 v:0x6ca860/NONE duplicate:0 <0xc04>
06 03/20/10 18:30:59.025 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: OK now: Waiting for job to finish #hooks: 0 upnp: 1 v:0x6ed4d0/NONE duplicate:0 <0xc04>
06 03/20/10 18:30:59.155 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 3 now: 3 #hooks: 0 upnp: 1 v:0x6ca860/NONE duplicate:1 <0xc04>
06 03/20/10 18:30:59.156 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: Waiting for job to finish now: Waiting for job to finish #hooks: 0 upnp: 1 v:0x6ed4d0/NONE duplicate:1 <0xc04>
03 03/20/10 18:30:59.158 JobHandler_LuaUPnP::Reload: QuitAfterThisJob Critical 0 m_bCriticalOnly 0 <0xc04>
06 03/20/10 18:30:59.180 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 3 now: 2 #hooks: 0 upnp: 1 v:0x6ca860/NONE duplicate:0 <0xc04>
02 03/20/10 18:30:59.182 Device_Variable::m_szValue_set 1 urn:micasaverde-com:serviceId:ZWaveNetwork1:NetStatusID=2 UpnpNotify=-116 <0xc04>
06 03/20/10 18:30:59.183 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: Waiting for job to finish now: Resetting ZWave Network #hooks: 0 upnp: 1 v:0x6ed4d0/NONE duplicate:0 <0xc04>
02 03/20/10 18:30:59.186 Device_Variable::m_szValue_set 1 urn:micasaverde-com:serviceId:ZWaveNetwork1:NetStatusText=Resetting ZWave Network UpnpNotify=-116 <0xc04>
03 03/20/10 18:31:00.479 LuaUPNP: ending <0x400>
Sat, 20 Mar 2010 18:31:00 +0000 - Exit code: 0
03 03/20/10 18:31:01.829 LuaUPNP: starting bLogUPnP 0 <0x400>
09 03/20/10 18:31:01.872 UserData::ParseRooms 1 Kitchen bSynced 1 <0x400>
09 03/20/10 18:31:01.873 UserData::ParseRooms 2 Office bSynced 1 <0x400>
06 03/20/10 18:31:01.876 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastUpdate was: EMPTY now: 1269109772 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.877 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: AutoConfigure was: EMPTY now: 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.878 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: EMPTY now: 2 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.880 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: EMPTY now: Resetting ZWave Network #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.881 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: ComPort was: EMPTY now: /dev/usb/tts/0 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.882 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: PollingEnabled was: EMPTY now: 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.883 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: PollDelayInitial was: EMPTY now: 20 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.884 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: PollDelayDeadTime was: EMPTY now: 10 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.886 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: PollMinDelay was: EMPTY now: 30 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.887 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: PollFrequency was: EMPTY now: 60 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.888 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: VersionInfo was: EMPTY now: 2.48 L:1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.889 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: HomeID was: EMPTY now: House: 62a81 Node 1 Suc 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.890 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: Role was: EMPTY now: Suc SIS:YES PRI:YES #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.891 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastDongleBackup was: EMPTY now: #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.892 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastError was: EMPTY now: Poll failed #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.894 Device_Variable::m_szValue_set device: 2 service: urn:micasaverde-com:serviceId:HaDevice1 variable: IgnoreRoom was: EMPTY now: 1 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.896 Device_Variable::m_szValue_set device: 8 service: urn:micasaverde-com:serviceId:Camera1 variable: Username was: EMPTY now: dceadmin #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
06 03/20/10 18:31:01.897 Device_Variable::m_szValue_set device: 8 service: urn:micasaverde-com:serviceId:Camera1 variable: Password was: EMPTY now: dcepass #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x400>
03 03/20/10 18:31:01.948 UserData::LoadUserData BuildVersion: 1.0.988 SvnVersion: Revision: 2415 flush: 0 <0x400>
02 03/20/10 18:31:02.308 Device_Service::MatchupUpnpServices no upnp service for urn:micasaverde-com:serviceId:Camera1 <0x400>
06 03/20/10 18:31:02.331 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastUpdate was: 1269109772 now: 1269109862 #hooks: 0 upnp: 1 v:(nil)/NONE duplicate:0 <0x400>
02 03/20/10 18:31:02.333 Device_Variable::m_szValue_set 1 urn:micasaverde-com:serviceId:ZWaveNetwork1:LastUpdate=1269109862 UpnpNotify=-116 <0x400>
06 03/20/10 18:31:02.335 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 2 now: 5 #hooks: 0 upnp: 1 v:0x6ca870/NONE duplicate:0 <0x400>
02 03/20/10 18:31:02.337 Device_Variable::m_szValue_set 1 urn:micasaverde-com:serviceId:ZWaveNetwork1:NetStatusID=5 UpnpNotify=-116 <0x400>
06 03/20/10 18:31:02.338 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: Resetting ZWave Network now: Configuring ZWave devices #hooks: 0 upnp: 1 v:0x6ed4d0/NONE duplicate:0 <0x400>
02 03/20/10 18:31:02.340 Device_Variable::m_szValue_set 1 urn:micasaverde-com:serviceId:ZWaveNetwork1:NetStatusText=Configuring ZWave devices UpnpNotify=-116 <0x400>
02 03/20/10 18:31:02.342 ZWaveJobHandler::Run connect to /dev/usb/tts/0 -0 lock 0 <0xc04>
02 03/20/10 18:31:02.618 ZWaveJobHandler::Run connected to /dev/usb/tts/0=1 i=0 <0xc04>
02 03/20/10 18:31:02.621 ZWaveSerial::InitializeRandomNumberGenerator warning for -3731 days <0xc04>
06 03/20/10 18:31:02.625 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusID was: 5 now: 5 #hooks: 0 upnp: 1 v:0x6ca870/NONE duplicate:1 <0xc04>
06 03/20/10 18:31:02.626 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: NetStatusText was: Configuring ZWave devices now: Configuring ZWave devices #hooks: 0 upnp: 1 v:0x6ed4d0/NONE duplicate:1 <0xc04>
03 03/20/10 18:31:03.881 ZWJob_Initialize::JobDone version 2.48 type 1 role is 2 house id 62a81 node id 1 suc 1 IsSecondary 0 bOnOtherNetwork 0 NodeIdServerPresent 1 IsRealPrimary 1 IsSuc 1 <0xc04>
06 03/20/10 18:31:03.890 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: VersionInfo was: 2.48 L:1 now: 2.48 L:1 #hooks: 0 upnp: 1 v:(nil)/NONE duplicate:0 <0xc04>
02 03/20/10 18:31:03.892 Device_Variable::m_szValue_set 1 urn:micasaverde-com:serviceId:ZWaveNetwork1:VersionInfo=2.48 L:1 UpnpNotify=-116 <0xc04>
06 03/20/10 18:31:03.893 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: HomeID was: House: 62a81 Node 1 Suc 1 now: House: 62a81 Node 1 Suc 1 #hooks: 0 upnp: 1 v:(nil)/NONE duplicate:0 <0xc04>
02 03/20/10 18:31:03.896 Device_Variable::m_szValue_set 1 urn:micasaverde-com:serviceId:ZWaveNetwork1:HomeID=House: 62a81 Node 1 Suc 1 UpnpNotify=-116 <0xc04>
06 03/20/10 18:31:03.897 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: Role was: Suc SIS:YES PRI:YES now: Suc SIS:YES PRI:YES #hooks: 0 upnp: 1 v:(nil)/NONE duplicate:0 <0xc04>
02 03/20/10 18:31:03.900 Device_Variable::m_szValue_set 1 urn:micasaverde-com:serviceId:ZWaveNetwork1:Role=Suc SIS:YES PRI:YES UpnpNotify=-116 <0xc04>
04 03/20/10 18:31:03.902
If any more info is needed, let me know.
Regards,
Tjardick
