I’m having a Horstmann HRT4-ZW that is not regulating normal, former I have used this thermostat with a fibaro relay and it have worked fine, and the last year I have used the Horstmann to controll a Aeon Labs DSC17 (http://www.smarthus.info/product_info.php?cPath=1_46_129&products_id=2130) and it have worked fine for a year. Suddenly now it’s not behaving the way it should be. When it set the “set temp” to be 5 degrees the temp is rising to around 13-14 degrees. Does anybody have an idea what’s wrong?
Check configuration variable 3 on the HRT4-ZW Device Options tab. It sets the temperature differential of the thermostat in tenths of degrees. The Vera default is 10 for one degree.
[quote=“RexBeckett, post:3, topic:177717”]Check configuration variable 3 on the HRT4-ZW Device Options tab. It sets the temperature differential of the thermostat in tenths of degrees. The Vera default is 10 for one degree.[/quote] The variable was 10.
I removed the the association group nr 2 and readded it, no it’s working fine.
