Horstmann c17-zw & hrt4-zw Vera 2
Hello everyone hopefully someone can help me out a little here (I’m probably being dumb)
I have a vera 2 running UI5 and firmware v1.5.622
I wanted to integrate my central heating system into it so purchased a horstmann c17-zw & hrt4-zw bundle.
The hrt4-zw integrated perfectly and works as expected I. E. Displays correct temp and I can control the set points etc.
However the c17-zw unit (the mains powered boiler controller bit) gets added to vera as an appliance module (binarylight1) and will not switch when I select on or off although it transmits ok.
All the information gets displayed I. E. Name and capabilities etc.
I tried changing the device file to thermostat but it just says not configured.
I’m at a loss now and wonder if I either have to try and make some kind of device file for it or if there’s one floating around somewhere. Or even if I’m just doing something wrong?
I want to get this sorted then I’m looking at adding in a trv (which is already included and works) just need to tie it all together.
