Honeywell YTH8320ZW1007 compatability
Can someone please tell me if the HONEYWELL YTH8320ZW1007 ZWAVE thermostat will work with Verde Lite? Ifo so can you give me exact directions on how to pair and which MI CASA APP I would use to operate this remotely from my computer, iPAD and or iPhone.
Hello,
I have this thermostat but it is with vera2. You have to go under setup (by pushing the system button then press 3rd and 5th box at the bottom of the screen, there will be nothing in the box but just press and hold it until the screen changes)… Then set up all the features your a/c has, then set your zwave box to add mode then on the thermostat go down till you get to rf10 and select 1 to add… That should be it. It is all in the installation manual…
