Honeywell Vista 15p envisalink 3DS TPI status OFFLINE
Hello,
Been wrestling with this for a while.
I have the envisalink working properly via eyezon site and locally. I am able to arm/disarm, have zone followers setup.
I installed the DSC plugin for veralite UI5 and configured according to wiki.
I always see TPI status as offline.
In veralite logs I see
luup_log:26: DSCAlarmPanel: debug processIncoming:: Command=empty, Data=‘empty’, Checksum=empty <0x2df66680>
LuaInterface::CallFunction-2 lu_incoming failed [string “…”]:1087: attempt to concatenate local ‘cmd’ (a nil value) <0x2df66680>
I have connected both the veralite and the envisalink to router and also to same switch to test. Still no TPI status Online.
I have also reset veralite and started from initial setup and currently only have the DCS plugin installed.
Any ideas???
Thank you
The DSC plugin is only built to interact with a DSC Alarm panel.
No other interactions are supported, even if the conduit/interface (eg. Envisalink 3DS) supports alternate Alarm Panels being at the other end.
Bottom line: If the interaction isn’t 100% a DSC interaction, we won’t handle it.
