Honeywell Thermostat Energy Mode UI7 broken?
I have a Honeywell Thermostat… used to have heat set to 73, and energymode heat to 66. In fact, that’s how it is manually set on the thermostat.
When I leave my house, I woudl set the thermostate to energy mode and it would use the 66, when I get home it would switch to normal and set to 73.
Now, setting to energy mode doesn’t seem to do anything.
In the UI (just upgraded to UI7 recently), I see some weird things… a) duplicated entries, and nothing to shwo the 66. b) Setting the thermostate via the UI to Energy, doesn’t update the temp setting.
CurrentTemperature 73
CurrentSetpoint Heat 70
CurrentSetpoint Cool 82
CurrentSetpoint Heat 73
CurrentSetpoint 70
SetpointTarget 70
I was thinking also, that setting the thermostat to EnergMode / NormalMode would automatically change the setpoint to the target value. But it seems that it keeps the value that it is currently set to.
Yeah, Mine has had this problem since going to UI7, I don’t understand why the Vera team will not fix this issue, there is another topic on this where the fix has been said to “come soon” but I can’t find it at the moment. I have spent a lot of time thinking I need to do something, but I’m no guru with zwave or vera and have too many other areas to practice in.
