I am somewhat new to Z-wave and am slowly outfitting my house. So far I have 7 Honeywell TH8320ZW1007/U thermostats installed an linked to my account. Everything is working however two the thermostats register a wattage readout on my web interface dashboard. Is it something I did differently when I linked those two units to my Vera Lite? If not should I unlink them and try relinking again?
Chris
If you go to the advance tab of one of the devices (clicking the wrench icon). Scroll down, do you see something like A “Watts” field?
Yes. There is a Watt’s Field and Current Level Field. These fields are not present in the other thermostats advances settings. I’m wondering if I should just remove and reconnect these to the system.
Chris
Excluding and re-including should correct the issue.
Thank you for your reply. I’ve been busy after work and haven’t been able to delete them and re-include them into the system. Do you know if I will have to then rebuild the scenes they were in or will it recognize that particular device as it was before I deleted it?
Thanks,
Chris
