Has anyone looked into using this alarm system with Vera?. That would be a good combo I believe.
Any info/progress ?
Do you have 5800zBRIDGE installed?
I just looked at the 5800zBRIDGE datasheet. From what I can tell, it only receives commands from the Lynx and sends them over Z-Wave. It doesn’t look like Vera can send arm/disarm commands TO the Lynx.
It looks like I may be headed toward a Honeywell Vista system. I’d like to keep my investment in my Honeywell sensors ![]()
Bob
Haven’t heard anything new on this subject. Could a device like this be integrated in the chain
http://www.fortrezz.com/3.html
The current firmware does not use the contacts or motion sensors for anything other than alarm. You can’t use a door contact to trigger a light on. this is suppose to be coming at some point… as per the Honeywell Tech support.
