Homewave is crashing
Seems since I upgraded to the latest version of IOS 7 last night that Homewave crashes right at start-up. Any idea what could be causing this?
Anybody else having this issue?
[quote=“Grwebster, post:2, topic:184116”]Anybody else having this issue?
Sent from my iPad using Tapatalk[/quote]
Are you referring to the latest version of UI7 for Vera? If so - no I am not having this issue. Homewave has continued to work just fine for me with the latest version of UI7.
Yes latest version. I also run slightly different designs on my iPhone vs my iPad. Both are crashing. Also two different IOS versions. (6 & 7)
This problem continues to haunt me Home wave is unusable for me on both devices :frowning:
It happens sometimes that an iOS app (not just Homewave) goes wonky; usually deleting and reinstalling the app does the trick. Keep in mind that you will lose your configuration if you haven’t saved it to dropbox.
I have not had any other reports of the app crashing after an iOS upgrade, and it’s even stranger that it happens on 2 devices. Another thing you can try first is to put your phone / tablet in flight mode, then start HoneWave. This to rule out some exotic network issue triggering a bug.
Thanks for the reply. My next step was to delete the app, but I will try opening in airplane mode first. This is still my favorite app.
Deleting the app worked. My last backup was a little old, so I lost a few changes, but no big deal. Thanks for the help. :smiley:
