HomeWave and two sites
I am in process of setting up Vera 3 systems in two homes. Can HomeWave be set up to connect to two different sites, one at a time, and if so how do you set that up?
Set up HomeWave for one site, save the configuration, then start over and configure for the other site. You can now just load the configuration you need and use that. MIOS credentials etc. are saved along with the config.
Thank you for your reply. I have one site already configured and running. Once I get the second Vera 3 system running and I am sitting at the second site with my iPad, what do I do to “start over” with HomeWave?
You can’t, really :slight_smile:
Quickest way is to just delete all control screens (add a new one before deleting the last old one). Then set up everything, and configure the second Vera (IP address / MiOS) in the Settings app, HomeWave section.
Maybe I am just being dense, but that sounds like HomeWave on my iPad can be used only on one site and cannot switch between house 1 and house 2.
Correct, currently you have to switch configurations to use each Vera. There is no simple switching back and forth yet.
  • Garrett
Thank you. I hope they add that capability in later versions. Anyone with a second home could use the capability to monitor more than one site.
Intveltr has already stated that he will add support in a future version. This is not the first time this was brought up. There are other posts talking about this.
  • Garrett
[quote=“garrettwp, post:8, topic:178098”]Intveltr has already stated that he will add support in a future version. This is not the first time this was brought up. There are other posts talking about this.
  • Garrett[/quote]
Hi–
A new version of Homewave has been made available that now handles more than two veras.
   Don
