HomeWave 1.75 around the corner! Multiple Veras & more
This release should hit the App Store in 1-2 weeks.
NEW FEATURES:
[ul][li]Support for multiple Veras. You can now control 2 Vera’s at once (support for additional Vera’s to be added in an upcoming release). Enter details for your 2nd Vera in the Settings app.[/li]
[li]Sonos / generic AV support: New control types allow you to control Sonos or generic AV devices: play, stop, next, and selecting a playlist or radio station. Volume can be controlled using a Dimmer control. An on/off control can be used to mute / unmute the device.[/li]
[li]Option to link Dimmers and Thermostats to additional devices, in order to control all of them with a single control. Add the Vera device IDs for additional devices under the “Linked devices” property, separating multiple IDs with commas.[/li]
[li]If there is no network connection to Vera, operating controls linked to it will now result in a red flash indicating an error.
[/li][/ul]
FIXES:
[ul][li]Fixed issue with thermostat control: when this set to control “temperature” and with the thermostat in auto mode, it will now correctly display/control the heat setpoint when the system is heating, or the cool setpoint when cooling.[/li]
[li]Fixed issue with Navigation control: sending service requests to Vera now works.[/li]
[li]The scene selector for Scene controls no longer shows hidden scenes (used by Vera for notifications).[/li]
[li]Fixed crash that may occur when using a “rose” type control together with a PIN entry (Alarm Panel control).[/li]
[li]Improved the appearance of slider controls in iOS7.[/li]
[li]Info screen now shows correct (unescaped) Push notification ID for the HomeWave Push plugin for Vera.[/li][/ul]
Excellent! 8) Looking forward to the release. An extra plus for the Sonos support.
Just bought the current version, cant wait for the update! Thanks for supporting the app so well!
V1.75 passed inspection and is in the App Store now.
Multiple vera support… Awesome!
Sonos features work great! But how do you choose playlist or station? Nothing happens when either of the two buttons are pressed.
Odd… In the Vera UI, do you have the option to choose a radio station or playlist in the Sonos Plugin? HomeWave should have the same information.
Hello Intveltr !
one more time you exceeds in quality of your great product: HomeWave!
I have installed and is working fine, about sonos feature I observe this:
when I select a radio from my favorites the radio is played fine.
but when I click in playlist to choose one of that listed to play, suddenly appears a red cloud in the right up corner and from this moment the home wave app do not more works…is all the time with red indicator in the up right corner. the symbol of wifi connection is changed for a cloud like that when I am using 3G connection out of my home.
this playlist was created using sonos app and from this app (sonos) I can play it without problems.
thanks for the great job…
Weird… can you enable logging please, try to run the playlist again, and mail me the log? Thanks!
I all of a sudden got the list of radio stations to work but it seems I get the same behaviour as Piwtorak. Also, the zone plays, pause, plays, pause… after a station has been chosen. The list of playlists still doesn’t work.
I as well will try to fix the debug for you.
Freddan101, please send your log to intveltr, I am away from home !!
thanks !
Got a few bugs:
  • Playlist / radio stations not appearing. This is due to some weirdness in the XML returned by the Sonos plugin. Sometimes I get an extra nested array in there.
  • Selected playlists starting over and over again. This is a network timeout issue; sometimes the response from the Sonos plugin takes a long time to arrive. Workaround is to increase the LAN timeout in HomeWave settings. This also causes the red connectivity icon
  • Playlists not starting at all: can be due to weird characters in the playlist name.
I’ll push out an interim version to address these.
There is also an issue with long Sonos playlists; when such a playlist is active, Vera pumps out an enormous amount of data in the form of the full playlist in an inefficient XML format. This could cause HomeWave to think there are connection issues due to network timeouts.
There is a new version of the Sonos plugin to address this issue, but it is not compatible with HomeWave. The upcoming version of HomeWave (submitted today) will fix this.
Well done! Then I suppose you won’t need the debug log this time. Will try out the new version when released.
How does one achive “Option to link Dimmers and Thermostats to additional devices, in order to control all of them with a single control.”?
Open the properties for the dimmer, and enter the comma-separated list of device IDs for the other dimmers in the “Linked devices” field. These have to be on the same Vera. Use the Vera device ID (not the Z-wave one).
Great! I will try this out.
Running 1.77 for a few days now. Seems good but I’ve noticed some lockups where status of devices has a long lag. I’ve changed a few devices and added a couple lately so maybe a Vera thing and not homewave.
I also started using presets on my PT cameras. Two things come to mind.
  1. can you make the # of presets shown configurable. I only use 3 on one cam and four on the other.
  2. would be nice if you could place the presets where you want. Not locked to 2x3 grid in top left corner. Maybe a single horizontal row of three in bottom right. A vertical single row of four on the top right side…
Love the app!
Same here. There is definitley a slower response when receiving confirmation of a sent command in 1.77.
There has been a small cosmetic change. In the past, buttons would appear to flip instantly. In 1.77, they go to the “unknown” state until Vera responds that the command has been received. A few people have requested this so they would have positive, reliable feedback on commands when connected remotely on a poor connection.
