Wife went and got an ADT Pulse system (yes I know…) with 2 Zwave thermostats, and a few other wave items.
From what I have read, the ADT system will not share the table with any other controllers, so I assume by reading this I can’t setup scenes on the vera with the same devices… I either have to select the Pulse or the Vera.
I would like to hear from you folks to see what your thoughts on how to integrate (to whatever level of functionality is possible) these two systems…
How should the vera be setup (if I even use it) and will there be any issues with 2 Zwave networks running in a house?
Integration, if there is any to be had, between these two systems is going to be a mess.
You can have more than one Z-Wave network in the same house.
Since you presumably have to pay for it either way, I’d try the ADT system. It’s something new to play with and might meet your needs. And if you’re keeping the wife, you don;t want to hear about how you broke her new system, do you? If it doesn’t meet your need, exclude your preferred Z-Wave devices from the Pulse system and include them into Vera.
I have given this same issue some thought as I inflicted the same issue on myself with a 2Gig based system before I developed an understanding of more robust home automation systems.
The only solution that I ever thought up that would bridge the gap, and with limited understanding of the intricacies of Z-Wave, is to have a Z-Wave device that has power sensing or energy monitoring with a second z-wave plugin module plugged into that. With this, you could convey to the Vera that the alarm is on or off (and probably convey nothing to the alarm). It would be a messy and limited solution, and in the end I opted to abandon this and to leave certain exterior devices connected to the alarm system and the vast majority of devices connected otherwise.
