hidden action after deleting device
I had an outlet fail and I had to delete it from the vera. My PLEG instance shows 1 action but when I go to the immediate section it has no action. I added a new action and even though there is only one in the list, it shows 2 actions now. In UI5 I would have just edited the variable but now there is a checkbox and I’m nervous about messing with it.
PLEG should detect the device is missing and remove it … I will double check the logic.
It should not hurt anything, waste a little time sending a command to an unknown device.
You can also remove alll actions and add the 1 action back.
