I am pretty new to Vera. I have made some progress creating my own IR plugins by modifying existing xml files, but now I am stuff trying to control my Tivo over Ethernet using telnet. Anyone want to help me get started with that? Are there any basic plugins that control something over telnet that I can start from?
@PurdueGuy,
If you wanted to let multiple things “talk” to the same TiVo, you could cutover to using the builtin LuaSocket library directly, instead of using the built-in TCP connection management.
You’d want to guard the connection logic (maybe use a [tt]pcall()[/tt] block), so you close out the sockets in all the cases, as well as use [tt]settimeout()[/tt] to some realistic value. Other than that, it should be a simple thing to cutover to if you wanted to avoid the middle-proxy.
Ok, I cut over to the LUA socket library. This is NOT complete, but it does work for TiVos. I may or may not make more mods this weekend, but I wanted to include them for now.
I based this on the DirecTV plugin I found, but modified the namespaces to (hopefully) avoid conflicts. My apologies to the original authors for butchering it!
The “meat” is in I_Tivo1.xml, in the “sendCommand” function.
This is FAR from perfect, but so far, does what I need. I do plan to add a few more buttons, but I don’t have a use for them yet.
Thanks for the code, I am using it as a template for supporting my IP set-top box as well. Did you develop the JSON file by hand or did you use a tool to generate it? I’d like to add/change some buttons …
[quote=“capjay, post:9, topic:169940”]Thanks for the code, I am using it as a template for supporting my IP set-top box as well. Did you develop the JSON file by hand or did you use a tool to generate it? I’d like to add/change some buttons …[/quote]I did it by hand. I was only going to do a few buttons, then I kept going!
@PurdueGuy: Thanks a bunch! Works great on my Tivo Series 3.
(I tried to do this myself a while back and failed. Studying your code to see what I did wrong…)
I have my “Watch TiVo” scene which turns on the TV, A/V receiver, then sets the TiVo to the “Now Playing” list, without the preview window. Then I don’t risk seeing the end of shows, sports scores, Olympic outcomes, etc.
Also, my “bedtime” scene will pause TiVo and exit to live TV. I do that b/c older versions of software wouldn’t remember a paused position if you don’t exit out of the program. If the pause point isn’t marked, you can’t transfer from the paused point, and have to transfer from the beginning, and wait to catch up to where you left off.
And I’m a gadget geek, and like having everything linked. ;D
Real new to this and getting my setup started. How do I actually install these plugins? I have a Vera Lite and a few switches right now but I’m quickly expanding my network.
Thanks,
Michael
[quote=“PurdueGuy, post:7, topic:169940”]Ok, I cut over to the LUA socket library. This is NOT complete, but it does work for TiVos. I may or may not make more mods this weekend, but I wanted to include them for now.
This is FAR from perfect, but so far, does what I need. I do plan to add a few more buttons, but I don’t have a use for them yet.[/quote]
You then upload the four file to your Vera from you menu APPS > Develop Apps > Luup Files. On the right side of the screen you choose the files, one per line and on the bottom click the check box and click upload. On the top of that panel you should see a message upload successful or words to that effect.
You now need to go to the Create Device menu and follow the instructions in that post by typing in a name and Upnp Device Filename entries etc.
OK - I’ve created the device (I think) but I’m confused as how to access it. It shows up in the list of devices and I can go in and edit the properties - but how do I actually use it?
What worked for me was to set the IP for the Tivo under the device properties “ip” field. Then create a new scene, select the advanced tab, pick a device - the TiVo, and from the drop-down list select a command.
