I was able to stumble my way through (thanks to the forums) getting my door sensors to trigger my thermostats to shut off if a door is left open. But it took me a while.
I want to create a pool door alarm sequence like the pool door alarms that you can buy (GRI brand). Here is an outline:
-Door sensors
*When a door is opened…
-Delay
*wait 7 seconds
-Push button device
*If the button is pressed, do not sound the siren for 7 seconds
*If the button is not pressed, sound immediately
-Sound the siren
**If the door is opened and closed without pressing the button, the siren sounds
**If the button is pressed BEFORE or AFTER the door is opened (within 7 seconds), the siren does not sound for 7 seconds after the door is opened
I am willing to pay for someone to program this for me and I can give you user access while it’s being programmed.
Anyone? Is what I’m wanting to do even possible?
[quote=“sowalsup, post:1, topic:189228”]I was able to stumble my way through (thanks to the forums) getting my door sensors to trigger my thermostats to shut off if a door is left open. But it took me a while.
-Door sensors
-Delay
*wait 7 seconds
-Push button device
-Sound the siren
I am willing to pay for someone to program this for me and I can give you user access while it’s being programmed.[/quote]
Do you have PLEG setup and have your input devices setup in PLEG? I think you haven’t got a response since your asking for everything. It’s one thing to ask a single or directed question but your question is so broad and I don’t have an understanding with what your PLEG skills even are yet.
EDIT: If you post your PLEG “Status” report in PDF form it will greatly help us see what you have and be able to give you feedback or a condition that will work for you. This is assuming you have PLEG installed and semi setup.
Yes I have PLEG installed on one of my hubs/properties, but like I said it took a while to get it programmed. Before I purchased all of the door/window sensors, fob/buttons and siren I was hoping to find out if anyone thought it could be done. I realize it’s not a targeted question I have.
This seems fairly complicated (to me) when you consider the different elements:
-The siren doesn’t sound if the button is pressed 7 seconds before opening the door
-The siren sounds 7 seconds after the door is open unless the button is pressed
-The siren still needs to sound 7 seconds after the button is pressed if the door remains open.
-The siren sounds even if the door is opened and shut immediately without the button being pressed.
Let me know if you have any thoughts about this being programmed.
[quote=“sowalsup, post:4, topic:189228”]Yes I have PLEG installed on one of my hubs/properties, but like I said it took a while to get it programmed. Before I purchased all of the door/window sensors, fob/buttons and siren I was hoping to find out if anyone thought it could be done. I realize it’s not a targeted question I have.
Let me know if you have any thoughts about this being programmed.[/quote]
Post your PLEG status report in PDF and we can help you write a condition.
