hi!
Scenario : I want to turn on my light when the sensor i Tripped without making a triggers tab. Only with LUUP.
Also want the code to run auto when i click Run scene.
Code im using now only turn’s on light if sensor is tripped == 1, but i want it to check it all the time.
[code]local sensor = 18
local light = 4
local SS_SID = “urn:micasaverde-com:serviceId:SecuritySensor1”
local Tripped = luup.variable_get (SS_SID, “Tripped”, sensor)
if (Tripped == “1”) then
luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”,“SetTarget”,{ newTargetValue=“1” },light)
end[/code]
