Trying to wrap my head around luup.io.intercept() can someone help with the following: -
- Send command in raw mode.
- Wait for 3 byte reply.
- Send command again.
My understanding is that the intercept should go in before the send and it will receive on byte then reset as per the following code: -
[code]function DIDIOTransmit(Command, DALICommand, commandType)
local byteCount = 0
local commandRepeat = false
local byte1 = string.byte(Command, 5)
local byte2 = string.byte(Command, 6)
log("(DIDIOTransmit) commands:" .. string.format("%02X",byte1) .. ":" .. string.format("%02X",byte2) .. ":",3)
if (tonumber(commandType) == 1) then
if (DALICommand == DALI_INIT or DALICommand == DALI_RAND) then
commandRepeat = true
else
if(luup.io.write(Command) == false) then
log("(DIDIOTransmit) fail:" .. string.format("%02X",byte1) .. ":" .. string.format("%02X",byte2) .. ":",2)
return false
if(commandRepeat == true)then
--loop goes here to detect 3 bytes
while(byteCount < 3) do
incoming_data = luup.io.read();
if (incoming_data ~= nil) then
log("DIDIOTransmit:incoming data:" .. string.format("%02X",tonumber(string.byte(incoming_data))))
byteCount = (byteCount + 1)
luup.io.intercept()
if(luup.io.write(Command) == fail) then
return false
return true
return true
end[/code]
I seem to be getting inconsistent results so was hoping someone could point me in the right direction.
The code above is causing restarts?
John
