http://192.168.1.72:3480/data_request?id=lu_action&DeviceNum=3&serviceId=urn:upnp-org:serviceId:HVAC_UserOperatingMode1&action=SetMode&Mode%20="Off"
I am trying to set the mode to off on a CT22 Radio Thermostat via HTTP and I received an error “ERROR: Device does not handle service/action”
Can some one tell me what I am doing wrong? I will like some example if possible to read the temp and status.
guessed
November 11, 2011, 3:15am
2
A few issues:
a) The Action is [tt]SetModeTarget[/tt], not [tt]SetMode[/tt]
b) The Parameter is [tt]NewModeTarget[/tt], instead of [tt]Mode[/tt]
c) You have encoded space ([tt]%20[/tt]) and doubleQuote ([tt]%22[/tt]) characters in your URL that should be removed
… at least according to [tt]S_HVAC_UserOperatingMode1.xml[/tt], assuming Vera is on 192.168.1.72:3480
http://192.168.1.72:3480/data_request?id=lu_action&DeviceNum=3&serviceId=urn:upnp-org:serviceId:HVAC_UserOperatingMode1&action=SetModeTarget&NewModeTarget=Off
Also, besides the XML, have a look at the wiki .
@guessetG
Thanks for your time, is working.
@oti
Thanks for the link, that really help.
@guessed
I run almost to the same problem with this one:
http://192.168.1.72:3480/data_request?id=lu_action&DeviceNum=3&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&action=CurrentTemperature .
to request the temp.
I there any document that show command for most of the devices? So I can take a look
http://192.168.1.72:3480/data_request?id=lu_variableget&DeviceNum=3&serviceId=urn:upnp-org:serviceId:TemperatureSensor1&Variable=CurrentTemperature
Ap15e
November 11, 2011, 6:58pm
7
Consult
[tt]http://wiki.micasaverde.com/index.php/Luup_UPNP_Files[/tt]
for a list of UPnP actions and consult
[tt]http://upnp.org/resources/upnpresources.zip[/tt]
for a list of arguments.
Do not assume that all actions/arguments are implemented and do not assume that the contents of [tt]upnpresources.zip[/tt] is consistent (cf. [tt]http://forum.micasaverde.com/index.php/topic,8386.msg53432.html#msg53432[/tt] ).
